Black Mammoth
- January 11, 2002
- Christiansburg, VA
- '01 Eddie Bauer
So I had my wife take the Explorer in to a tire shop to get an alignment. They told her that there was too much vertical movement to put it back in to alignment. They said the lower ball joints are bad.
So I decided to put the car up to see what else I should replace. I thought I would also try to verify that the ball joints were bad. So I put the car up on jack stands. Then I pulled the wheel in all kinds of directions without any movement. Also, the ball joints don't show any signs of leakage. I know I may not see anything if the grease is all used up, but I thought I would see something.
I do know that I have negative camber wear on my tires. The inside of the tires almost bald. The Explorer has 83k miles on it with original tires and ball joints.
What do you guys think? I just hate replacing parts if they are fine. I guess I can spend more money taking it somewhere else and see what they say.
Thanks
Thanks
