how do I calculate what speedometer gear to use? | Ford Explorer Forums
bgracen
I went from 235x75x15 to 31" tires and I have 3:55 gears. How do I correct my speedometer to read accurately? Thank you.
You need to know a couple of things...
1: what is the difference from the old tire size to the new size (actual percentage).. or how far off is your speedo (what percent)
2: How many teeth do you have on your current speedo gear (driven gear)
Once you know those two you call a speedo shop and tell them you have an x tooth gear and need to change it x%. They can then get you the correct gear (or at least get you closer)..
If you can't find the gear you need I have a friend at a Speedo shop that can get it for you but any decent speedo shop or sometimes even the ford dealer can get you the gear.
Mark
mark@legendz.com
http://mark.legendz.com
Off-Road and Motorcycle Information, Pictures and Movies
Click Dead Link Removed to see our Explorer Specs
Search around the site for this and you will find all the info you need. You can get the gear at a dealership for around $10 and install it in less than 5 mins.
Brian Corff
Dead Link Removed
"Beware the lollipop of mediocrity. Lick it once and you suck forever."
Maniak: My '91 has an error of about 6 mph on speed. However, the odometer error is <3 miles in 1,000. How can I correct the speed error and not mess up the odometer?
Thanks in advance for any help.
Barnstormer
'91 stock 4X4
