How do I check if Injectors are firing? | Ford Explorer Forums
87yj
West Texas
Had a 93 Sport
I'm still fighting a no start problem with my 98 explorer 5.0 engine.
How can I test if the computer is firing the fuel injectors?
I've got fire and fuel pressure already...not sure if the injectors are firing or not?
Please help!
The best way is with a logic probe.
The power wire to the injector should have a solid red light on the probe
the ground wire should have alternating green and red lights with flashing yellow too.
A logic probe is $12 @ radioshack.
Fuel injectors can usually be heard using a stethoscope. Alternatively, you can get a little gadget called a "noid" light that hooks up to an injector and flashes as the computer energizes the injector.
FYI. You can only reach 3 of the 8 injectors with the intake manifold in place.
I would try the stethoscope first, Autozone sells them for 10 bucks with a long metal probe on them. Disconnecting the plugs could lead to breaking the plastic tabs on the wiring harness.
Next step would be the logic probe or a NOID light. Some carparts places rent them for free.
