wabbit
- March 2, 2000
- Western Colorado
- the white one...
I'm installing a cooling fan in front of my transmission cooler. I want to be able to operate the fan manually by a toggle switch on the dash and automatically by a thermo switch in the trans fluid line.
Right now I have a fused line off the battery that splits to both the toggle switch and the thermo switch. The "outs" from the switches come together to the fan lead wire. I was expecting either switch to run the fan. The toggle does power the fan but when I turn off the toggle and turn on the thermo switch, it burns the 20A fuse on the supply off the battery.
Should this work??? (all grounds are connected)
Maybe a bad toggle or possibly some kinda line to ground when the toggle is off and the thermo is on?
Note: The toggle switch is lighted if that may be an issue. I'm hoping that the toggle switch light will also come on when the thermo switch is powering the fan.
Is a relay necessary and if so why, and how does it work?
Please help...
Please help...
