jtison
- December 20, 2004
- W Connecticut
- '94 XLT/155 Kmiles 4x4
The Ford Service manual for the Explorer gives specs for a "caster split" as a negative degree value of -0.8 degrees, plus or minus 0.4 degrees.
When the split is negative, which side is supposed to be greater than the other? Another way of putting this is "which side do you subtract from the other to determine caster split?".
My L caster is +5.4375 degrees, and my R caster is +4.8750 degrees. The difference between the two is 0.5625 degrees. Am I within spec or not?
Anybody know?
TIA,
--Jim--
Anybody know?
TIA,
--Jim--
