How have you run wire from the roof mounted lights | Ford Explorer Forums
major
Elite Explorer<br><img src="/forums/images/star2.g
Florence, South Carolina
'98 V8 2WD XLT
how have all of yall run the wire from your roof mounted lights to the battery. i want to keep the cab of the car as water resistant as i can so i was wondering how you ran yours.
I ran my wires through the rear cargo door weather seal. It works great and I did not have to drill any holes. Inside I ran the wires under the plastic trim at the roof to the switch and battery and relay.
Where is your switch Brian?
Matt
I drilled two... total of three holes (one hole ended up being directly behing a cross-bar so I had to drill again about an inch off) There all sealed up pretty well though.
I ran my wires accross my roof and then down throught the door seal and you can go it the cab from there or you can go through the fender to the battery. This way you dont have to drill anything. hope this helps.
