How I mounted 3rd gen headlights part 1 | Ford Explorer Forums
95ModdedX
Washington State
95 explorer Ltd
Parts needed:
New parts are cheap, pick n pull might be cheaper or Rockauto
3rd gen CarPartsDepot, Head Light Lamp Grille Support Mounting Panel, 404-18117 FO1221123 1L2Z8190AA $56. Amazon
3rd gen L & R headlights $25-$30 each Amazon
3rd gen Dorman Headlight Sockets, need 2 highbeam and 2 low beam Amazon
3rd gen headlight clip (4) 50-8222 HEADLIGHT RETAINER $14.95 each LMC Truck
find at salvage yard-LMC is too much at $60.
3rd gen Evan-Fischer EVA17772022955 Grille $40 Amazon (chrome or paint)
2nd gen L & R turn signals, you can cut up old ones or get new for $35 a pair Amazon
Discount Starter and Alternator FO2521130 FO2520130 Corner Light Pair
Check out the many choices for parts and prices, you might find better.
Mounting brackets to join panel parts are from my junk parts, find similar to use
Tools:
Mark parts to cut
To cut panels and turn signals I used hack saw, saber saw and dremmel cutting disc
I used files to dress up cuts on turn signals
drill screw holes first, fiberglass panels don't like screws
Skill and time:
If you like making stuff and solving problems on your Explorer this is a good challenge,
I spent many hours trying out ways to get this to work, the 3rd gen support panel is just too wide for 2nd gen
and useing the 2nd gen center saved a lot of work (air bag senser, grille trim still mount)
using 2nd gen turn signals solve the fender issue
Headlight wiring must be soldered and heat shrink for safety, no micky mouse wiring
Front facing turns are cut off so I put led turns in grille
Aim headlights when finished, mine came with bulbs.
Disclaimer; Don't do this mod if unsure about your skill or if illegal in you state, use Dot approved parts
have fun with your Explorer
part 2
part 2
part 3
part 3
I got to say it looks good!
Wow, this is really nice and uniquely different! A really fine job and mod :thumbsup::thumbsup:
better photos
Took out the head light to show cuts better
more photos
more photos
WOW, another nice job :thumbsup::thumbsup::thumbsup:
I mean... your work is great...
You did a good job, and it's certainly unique. I don't hate it, but I also don't like it. I might get used to it though, lol.
