jasonXLT2000
- January 21, 2011
- Milwaukee, WI
- 2000 XLT, 4x4, 4.0L, auto
I'm planning to swap out my stock shackles for WAR153's on my 2000 Explorer XLT. How important are new bushings?
There will be roughly 135,000 miles on the stock suspension when I make the swap, and I'm looking at the Energy 4.2124 bushing kit for all three pivot points on both sides in the rear (both ends of the leafs and the frame bushing for the shackle).
Reading other threads, I realize that removing the stock bushings can become a big job. So, if the stock bushings "look" like they're in good shape, how much performance/stability will these new polyurethane bushings add? Is it worth all the extra work and the extra $50?
(link to the product: http://www.energysuspensionparts.com/proddetail.asp?prod=4.2124)
With the wide colars that are flush to the shackles, one potential advantage I could see is these bushings adding a bit of resistance against lateral and tortional sway (since both the metal bolt housing and the bushing are flush to the shackles).
