How many quarts? | Ford Explorer Forums
How many quarts?
bfrombeebe
Beebe, Ar
'03 Sport Trac 2wd
How many quarts of transmission fluid do I need for a filter change? Everything I have read has a total capacity (including converter).
Is Mercon V what everybody uses, or is there somehting else that works better?
Owner's manual says Mercon V
Hi there... There should be a sticker in the engine compartment that tells you how much. I have a diff vehicle, but if you don't get an answer, you should look there. :salute:
