how much ATF does the tranny cooler hold? | Ford Explorer Forums
ogwutang
joplin, mo
97 AWD XLT 5.0
97 X, 5.0, 4R70W, BW4404. 155k miles
since i had the truck in the air pulling the transfer case, i decided to replace the radiator (it was leaking) and change the tranny fluid. after i put it back together, i put in 5 qts of ATF, and started it up and ran it through the gears. now the tranny is slipping real bad so i pulled the pan again. it had maybe 1 qt in it. you think it all went to the cooler?
never mind. i put in 5 more qts and everything works
