i've had two engine loose oil pressure. both spun rod bearings.
the first was my '74 scout (345 v8), i had a oil pressure gauge with a plastic line which broke, i was stranded so i did roadside repair cut the hose and tied it off) tested it, seemed fine.. drove about 2 more miles (on the freeway, towing a car up a grade) and the engine seized. temperature was still right on the N of normal when this happened. (it has a huge radiator though and it was a cool night) it had a couple spun rod bearings and all the bearings were badly scuffed. i rebuilt it.
the second was in my boat (455 olds v8) it lost oil pressure (also due to a leak) and it spun a rod bearing (and scuffed a couple others) i replaced the crank and bearings. the engine was not hot, but it had a whole lake to cool it too.
honestly i think by the time the engine is heating up from friction in the bearings, those bearings will be far beyond destroyed.
