Low oil presure and high oil temp light ? | Ford Explorer Forums
atcirco
Ellis,KS
04 Limited
Hi guys I bought my wife a 04 limted explore it has the 4.6 and is a 4x4 with 107k mi. I have noticed when the temp out side is below 80 the low oil presure light comes on and the high temp light comes on all at the same time,when you stop at light or stop sign. It only does this the first few times you stop. and only after the truck sits for more then a few hours. I should point out that the oil is not low it is fairly new. Has anyone had this problem were should I start? thanks guys
