jgilbs
- October 29, 2002
- Naperville, IL(home)/Iowa City, IA(school)
- 92 Eddie Bauer
is it okay to have any grease in the autohubs? I took mine off today and it is coating the entire inside of the hub (with the exception of the tip) is this OK? or should i use paint thinner to get it out? I had a problem that i thought was my hubs but when i jacked up the front end, they both engaged when i moved the front driveshaft. i tried to stick a piece of paper between the outboard pad and the rotor and i couldnt do it, leading me to beleive that i have 2 sticking calipers. now that i know why i have so much heat buildup, i am trying to find out if all the grease that traveled to the hub is bad or can i just leave it?
