How much lift | Ford Explorer Forums
How much lift
Buds007
Provo, Utah
97 xlt 4 door
Hi, I just ordered my explorer pro comps add a leaf and warrior shackles, and am wondering how much lift I can expect from them. I also will be installing a set of BFG AT T/A KO's, and am wondering how much ground clearance I will be gaining. I have a 97 XLT 4 door, completely stock. Thanks
About 2" with the Torsion Twist. You will be able to fit 31"x10.5"x15" Tires on your stock Rims.
Actually I ran that set up at stock height. That is what I ran for awhile a couple of sets of 31's. Then the TT with Old Man Emu's.
The only time I rubbed was when I went out in the Dunes here BAJA Style. In the front, I rubbed inside on top. Of course I was also jumping through the dunes at about 50mph.
If you go Add-a-Leafs & Warrior Shackles with the TT you may be a touch higher in the rear. It really depends on what you can get out of your front end with the TT. Some are only able to get an 1" while other's get 2".
Which when you lift the back it seems higher in the rear. You could get 2"-3" in the rear. I may even seem like 4".
I don't really know but I was told that if I went with the single add a leaf along with the warrior shackles I would get from 2 to 3 inches.
That was from a salesman at Four wheel parts so...
