How to adjust break light switch??? | Ford Explorer Forums
rnrphoto98
Weiser, Idaho
Explorer, 93 XLT 4x4
I need any ideas you might have on how to adjust the break light switch on the break pedal.
I found out that it is not staying in the proper position, if I pull it down a bit it will work for a few pushes of the pedal then it shifts back up, then no brake lights!
I am not sure what to use that will not get in the way to hold it down. I think tape would eventually slip, and there really isnt anything to get a zip tie around.
Your help you be great!!!
Thanks
Rob
