fjm
- June 7, 2008
- Orland Park IL
- 1996 XLT
Thanks to those of you who offerred help with my starting problem.
FYI, I isolated the problem to a busted actuator linkage that wasn't moving my ignition switch off the ACCESSORY, so all power stayed on. Now the car starts easily when I turn the key to ON and manually slide the ignition switch to START.
Does anyone know the correct or easy way to replace the actuator? Before I jump in, do I have to disassemble the steering and column to access? Would appreciate your input.
