Tarpman
- September 12, 2008
- Escalon, CA.
- 03 Explorer XLT 4.0
Hey all, I'm in need of some help. I've found threads about replacing "speed control sensor" on master cylinder, and fixing the problem. My ABS light has been on and off for about 2 weeks, and now sometimes when I step on brake with normal pressure it pulsates like its trying not to lock-up. I borrowed a scanner from a friend (Cen-Tech 98614) and can't really figure out how to use it. Checked for codes and said no stored or pending codes. Nothing about ABS. I'm wondering if it could be wheel speed sensor in rear end, but don't like spending $$ not knowing if it actually needs replacing, even if it is only $40. Could it be a vacuum issue with power booster? I would appreciate any help or advice, even opinions. Thanks guys
