steveissteven
- December 31, 2000
- LAS VEGAS, NEVADA
- '93 SPORT
It has been quite some time since my last post, but I still see there are quite a few discussions regarding Engine PING.
I too have dealt with the dreaded PING (power loss/engine bogging). Regardless of who I had look at my vehicle ('93 Explorer Sport 4.0), no one could offer a solution to my problem. Sure... everyone agreed the Engine Pinged like crazy, but no one had a fix other than "Try Running A Few Bottles Of Injector Cleaner!" I found this somewhat amusing considering I just had all of my injectors replaced with new ones from the dealer (Ford seemed to think my injectors were bad - it still did not eliminate the PING!).....
So I have indeed felt the frustration that many of you here continue to experience.... Until recently!!!
Here is the GUARANTEED way to eliminate PING:
First of all, PING is caused by an excessive amount of CARBON build-up
Now depending on how bad your vehicle PINGS (amount of carbon build-up in your engine), the below solution may need to be repeated as many as 4-5 times. My vehicle was quite bad, and I needed to perform the following 5 times (Possibly over-kill, but I wanted to be sure I cured it)
There is a product available at NAPA (Haven't seen it anywhere else) called "SEA FOAM"
If your engine is on the severe side (PINGS like HELL), I recommend purchasing about 7 cans of this product (It runs about $5.99 per can.
On a low tank of gas add 1 can, and then fill your tank half way / repeat this 2 more times once each 1/2 tank of gas has been used.
Add 1/2 a can to your Engine Oil
And finally - With engine at Normal Operating Temperature and Engine Running - Add 1/2 can of the Sea Foam through your PVC Valve - Again Engine Must Be running to ensure that Manifold Vacuum is able to suck the Sea Foam into the combustion chamber. Add it slowly or vehicle will die! Immediately after adding the Sea Foam - shut the vehicle off and let it sit for 15 minutes (The can says 5, but again... a serious case requires a longer time period)
After having let it sit for the 15 minutes, start your vehicle (There will be lots of white smoke out the exhaust - this is the Carbon being removed from your engine) Rev the engine for a while... or even drive it until the smoke clears - in my case this took about 5 minutes)
Repeat this procedure using only 1/2 a can at a time until your motor blows minimul smoke. I recommend doing this twice a day - like afternoon and evening -
Follow the above solution and you too will be as happy as I am...
"Sea Foam" is a great product
My vehicle has never ran better - I still use regular octane fuel (87) and ultimately.........
I HAVE NO PING WHATESOEVER!!!
Good luck!!!
Steven
Good luck!!!
Steven
