how to put in larger cable for the amp from battery | Ford Explorer Forums
hans the boss
halmstad city
1993and94 ford explorer
hi guys i realy need help now!!!!
okej i got my ford explorer XLT 94 i got stripped down all interrior for cleaning and more cables and some amps
but how in hell to get the cable from battery to inside the cabin
ok i got AC and v6 engine x 4.0 original all original on til now
i got an idea to take all AC away then mmake room for more fun in turbo install.. but okej
how do all of you when to go throuh the wall and were to do it my cables is about 3/8 thick so were to drill or maybe some rubber to go throuh i cant find any place to go inside the cabin
pleas tell me or som photos how to do it do i need mount down more of engine room????
If you look under your dash to the left of your brake pedal on the fire wall, you should be able to see either a rubber gromet in the fire wall, or you may have to pull some of the factory insulation out but there should be a circle cut in it already. You should be able to just stick a flat head screw driver thru there. Once you do that, shove a coat hanger or somthing in there so you can get it out into the engine compartment, tape your cable to that and drag it through. Or just shove the cable thru from inside and drag it out into the engine bay. It will come out right under your master cylender.
How is the instal going?
hi jstcruz.. well i got to ripp of mutch in the enginebay i can get the cable inside the cabin
i hawe to ripp of all of the ac and blower pices in the enginebay and now its snowing here in sweden and its WERY COLD OUTSIDE NOW 9-degrees
but i got installing the roof ligths 5 of them on the roof bar pics comming soon so i do little in time and trying to find out how to put pics in here?? well i keep up the hard work...thx !!
