Hartman
- October 16, 2001
- Indianapolis, IN
After many frustrations with removing the EGR valve on my 96 V8, mainly involving the lower bolt on the valve, I decided to share some of my experiences. This is a problem with the EGR system on earlier model V8s that have an internal EGR system (no EGR tube, no DPFE). The main problem is the bolt on the bottom of the valve, in which you have almost no room left, right, top, or bottom.
1. First, disconnect the electrical connection and vacuum line from the EGR valve
2. Remove the top nut that holds the EGR to the intake elbow (9/16")
2. Then you must gain some clearance for the bottom bolt. First, pull out the tranny fluid dipstick. Then, disconnect the small coolant line that connects to the intake elbow:
You will get some drips of coolant from the line. Tuck it out of the way.
3. There are many vacuum lines in this area...tuck them out of the way as best you can to gain clearance to the left side of the EGR.
4. To get to the lower bolt, you have a few options tool wise. You can cut down a 1/2" wrench or buy a stubby 1/2" ratcheting wrench. I chose to use this as an excuse to buy a set of ratcheting stubby wrenches
A ratcheting wrench will make things MUCH easier.
5. Use the stubby wrench to get to the lower bolt (1/2"). Clearance is still tight but you should be able to get it on.
6. Once the old EGR is out, transfer the position sensor over to the new EGR (3 11/32" bolts)
7. Reinstall EGR, replace coolant line and tranny dipstick, reconnect vacuum line and electrical connection to EGR.
8. Done.
8. Done.
