How to remove l/s front spark plug 4.0 SOHC. | Ford Explorer Forums
Mike65
Location
In my garage working on one of our vehicles.
Horsepasture, Virginia.
2005 2WD Regular Cab F150
I am replacing the spark plugs in our 99 Sport 4.0 SOHC & can not reach the l/s front spark plug. I tried a swivel & long extension with no luck. Any one have any ideas?. There is a tube right in the way, looks like an EGR tube that runs down to the l/s exhaust manifold. HELP!!.
its real easy. pull the tire off, then there is a fenderliner that has christmas tree clips holding it on, remove it, and bam! they are easy to get at, both sides. you need to go threw the fender to get them.
I have the 4.0 OHV, but it sounds like the same config--the EGR valve to exhaust tube is in the way. It's easy to pull the tube, though. Just two bolts on the EGR valve side and a large compression nut on the exhaust side.
And yes, lower the wheel well shroud as Vroom says. That gets you access to the compression nut.
Once I made my peace with pulling a few parts to make space, it got way easier to do the plugs. Now I can change them in 20-30 mins tops from start to finish, at a leisurely pace.
Spark plugs
Good advice. And if you use a standard wobble drive, you will have just the right size extension to get at all of the spark plugs on the passenger bank.
Thanks everyone for the tips.
