How to remove rear ABS sensor? | Ford Explorer Forums
02explorer04
Marietta SC
02explorer xls 04spottrac
How do I replace my rear ABS sensor, I was told this could be my problem with the ABS light coming on. And also, how do I flush the Brake system?
If they are the same as the solid 8.8s the sensor is right up top of the differential. Should unbolt and pull out. There is a way to test the sensor -using a AC digital mutlimeter hook up the leads and then spin the wheel to see if you get any current.
-Drew
To bleed the ABS system, just unplug the fuse, or the relay, and bleed it the same way as you normally would bleed a standard brake system. There was a recent thread about this, maybe a month ago. Just do a search on this website about bleeding ABS.
