HOW TO: Spark Plugs | Ford Explorer Forums
HOW TO: Spark Plugs
padeerslayer03
Jeannette, PA
93 Explorer
how do i go about changin spark plugs? Never done this before. I got a 93 X. Very hard??
The best thing would be to get your hands on a haynes or chilton repair manual. It will tell you how to do this and every other service (change fluids, gaskets, remove/install components) you will need to do. Well worth the $.
I've got a '97 AWD 5.0L. I have a Chilton manual, but it didn't tell me that I had to go in thru the wheel wells to get at the plugs! Not sure how accessible your plugs are on your X, but if similar to the '97 then:
Jack up the front, secure on stands, remove the front wheels, remove the mud skirts, and using a combination of socket extensions, remove and replace your plugs. When removing the mud skirts, be careful not to tear the material or break the clips. Grasp each expansion clip while holding the material firmly and pull it straight out. It takes a pretty solid tug to get each clip out. Don't be timid. Don't worry if you break a clip...you can buy new ones at your favorite auto parts store. Torn skirt, however, is not a good thing.
Thats a good way to approach it. It may seem like a little extra work but it will make the job alot easier.
