racprops
- January 25, 2019
- Phoenix AZ
- 2003 Explorer XLT 4.6 4WD
I have a couple of Electric fans off a couple of Panther cars, one off a 2000 Mercury and one off a 04 Crown Vic P71.
As these came off a 4.6 already wonder why they will not work great. EDIT Took a tape to it, darn too wide.
I would really like to keep the stock car set up of the fan not coming on until warm up and the two or three fans speeds,
on the Mercury it had a set of relays that controlled the fan speeds. But I believe those choices of fan speed was by the PCM.
It also would turn on the fan when the compressor cut in, that will be easy to wire a relay on the compressor to power the fan when it also turns on.
AS for the two or three temperature controls I fear I will need two or three adjustable temperature sensors that I can select the temperatures I want each fan speed to turn on.
Any one know of a better way??
Rich
Rich
