hub to hub measurment | Ford Explorer Forums
macknos94
Harrisburg, pa
2003 mountaineer premier
does anyone have the hub to hub measurement for our 3rd gens? i need the measurement for the front axle with and rear axle with while its on the ground. i would measure mine but there is about a foot of snow on the ground. any help would be great. maybe a southern buddy can help me out with this.
i can even work with a measurement of outside of tire to outside of tire if that would be easier but i would also need to know what off set, size(16x7), and tire size wheels you have on then i will work from there.
Don't forget that a suspension lift on the 3rd gen pushes that rear towards the front. I can measure mine for you, but it may be a little off because mine is lifted...but so is yours, so perhaps it would make it even closer than a stock measure?? :)
That would be a rough estimate since the tire's sidewall bulges and the offset is a property of the wheel.
I just need a rough idea of how wide of an axles I can use so and pretty close measurement would be great. I'm trying to find a vehicle that is about the same width. I'm looking to pull a set of junk yard axles to do a full build on them before I drop it off at a to z fab. I can go with a slighty wider or shorter axle I will just get the Right offset wheels to work with it
