huge rear window troubles | Ford Explorer Forums
rokr1292
richardsville va
'01 Explorer Sport Trac
Left the key on acc today and drained my battery. (All windows were open) After a little charge and letting it run to recharge itself for a few minutes, went to put the windows up, and tthe rear window won't move. Would a dead battery while the window's down make it need to be reinitialized?
I figured that was it, but after about an hour and a half of trying to get that procedure to work, I gave up. I can't figure it out. What might I be doing wrong?
I saw on the faq thread there was an alternate procedure, but google docs says it can't find that document. Is there an alternate procedure I could try?
Maybe it was just low voltage, itt makes sense, but idt my dads got a charger that would charge the battery before its supposed to rain tonight, is there any way to force the window back up until its charged?
Unfortunately ........... no.
Took it to a dealer, no dice. Tried the alternate procedure probably thirty times, diddly. took the back of the cab apart and tried to figure out if I could push the window up somehow, and a miracle happened. Just by disconnecting and reconnecting the connector just inches off the motor, all of a sudden, everything was working fine again. Still no clue what was wrong, but its working now.
