HVAC Issue only cold or hot air, nothing in between | Ford Explorer Forums
voltch
Atlanta, Ga
2013 Ford Explorer XLT
Original issue was that my vent control solenoid (the one that controls moving air from floor, to vent, to defrost) was stuck.
I worked on the wrong soleniod and damaged the tabs on the (temperature control) solenoid after opening it up, and then replaced it with a new one.
As far as my original issue where the vent control solenoid was bad, I replaced that solenoid too.
Now I am only getting heat when I put on HI, and AC when I put on low. Any temperature in between isnt working. So for example I can only get 85 degrees of heat or 60 degrees of cooling, but nothing in between.
Is there a way to reset the HVAC system or are there some more troubleshooting steps that I can do to resolve the issue?
When I replaced the heat control solenoid, I put it in the same position as the old one (there is a key and it only allows it to fit in one positon)
Also before all of this happened , I was able to select different temperatures, so I feel either something needs to be reset, something is in the wrong position somehow, or somehow the new solenoid has an issue.
Re
Genuine Ford AA5Z-19E616-C​
As far as I know, there is no way to "reset the HVAC' system". When you get the heat or A/C, are you able to direct the air flow using the various vent settings?
Yes, I can change from
Yes, I can direct the air flow from Vent, Defrost, Floor, Etc. The strange thing is that now I am also not being able to control the air flow in the reare rear. The rear Vent controls are no longer changing the airflow in the rear and I have not touched any solenoid related to the rear. I may go in and put the old temparature solenoid back in this weekend to see if that fixes anything.
