HVAC problem help ASAP! | Ford Explorer Forums
iforgited
Madison, WI
'99 Limited
I need help ASAP!!! I am living for school tomorrow and i need to fix my car tomorrow with my dad. Here is the deal, tonight i got into my car and turned on the heat cause it is getting cold in WI. The fan starting making a really loud annoying humming noise, it sounds like a mix between a prop plane and exhaust on an import. You can hear it inside the car and outside the car. It only gets louder as you turn the speed from low to high. I sounds like something is blocking the air from getting sucked up. It makes the noise in all positions, heat, ac, vent, floor defrost, etc. I have Electronic temp control and everything works on it like it slows its self down and speeds up like it is designed to so i think that is fine. It just doesnt seem to blow as much air as it used to and its really loud. Blower Motor? Blend door? Sorry this is so long winded, i just need help cause i wont be able to come back to my parents house for like three weeks and need a car at school.. Thanks for any help in adavance. Oh yeah my ex is a 99 Limited if that helps. THANK YOU!
