I am sure there is a reason why not to do this but | Ford Explorer Forums
Billy177
Redding CT
99 Explorer XLT SOHC 4x4
i am not planning on doing this but for an easy 3-5 lift why cant one install the reat diff assembly under the leaf springs instead of on top and just weld some brackets on tere or something besides you might need a new driveshaft
ya read very many lift threads ??:p
soem lift kits(most) require you to do this anywayz.
i know the 4" lifts coem with new rear springs tho.
the stock rangers come this way.....
PEACE
also shorten your Sig. its a couple lines to long
You could do a soa... But riddle me this: How will you lift the front?
Good luck! :D
spindles and torson twist
Don't use lited spindles on your 4x4. That is a 2WD thing.
also: trime to trim the sig to 6 lines please
Spindles on a 4x4? Nope. TT is 2" max. You still need 3.5"....
[edit] bah, robb beat me to it[/edit]
