I have a P0125 code Fixes anyone? | Page 2 | Ford Explorer Forums
Another issue I'm having is my speedo gear I can't see to get it right I have 3:73 gears and I'm running 31x10.5-15 my stock tire size is 235-75-15 I've sunk in over 50 bucks in speedo gears I'm at a total loss on what gear I need
The only other issue I'm having is with my speedo gear 3:73 and 31x10.5x15 is what I'm running now compared to 3:55 and 235-75-15 tires. Ive sunk over $50 in speedo gears into this already I'm getting frustrated with it. I would like to have 2 speedo gears one for the 235s and one for the 32s u guys gave any tips ideas or pointers that may help me out
Wow that is a nice kit. I'm for sure going to get that after I get the money. This is my plan for my build
1. Get Manuel shift t-case
2. Fix the rust issues I'm having
3. Rebuild the engine with that kit
The only thing I'm wondering is with the bottom end is could I bore .20 over and with that kit u showed me could I still run the stock PCM or would I have to go with a stand alone PCM?
And should I bother boring out the lower end?
Oh do u think a bigger throttle body would help?
Yup, once you start moving more air, everything gets bigger. You're. Would also benefit from a bigger elbow.
You also might need bigger injectors, and go with tuning. Now your in to an sct tuner and wideband o2. It truly doesn't stop.
Oh, and the kit I posted would be close, but that intake will probably take a bit of adapting for that elbow your going to make.
Search on post title " the elbow dilema "
Ok I will when I get a chance
That is a very good write up wow I'm a welder as my profession I'm impressed and yea machining can get spendy
