Nothinbutbadluck
- March 13, 2015
- Florida
- 2000 ford explorer
I ran ito an issue where the tc wouldn't lock up and so I had the pcm scanned it can back as the tcc stuck off. So I change the tcc (and the vb gasket as recommended) and checked for brass shavings for a hint that the tc may actually be going out to but I found no shavings. So being excited that I didn't have to change a tc I replaced the tcc and thought that I had found the problem..........after buttoning everything up I took in on a test drive and the problem persists. I have no shifting problems but I am at 2400 rpm doing 65 mph. Someone please shed some light on what else I need to check or what I should do.
