I need an innovative way of Bleeding the HCU on 94 ford exp sport 4x4 | Ford Explorer Forums
Arcticbreeze33
New Orleans, Louisiana
94 Exp Sport 4x4
Huge problem, I've changed my entire brake system, Because of stupidity.
I had a leak in the front passenger side line, but because the flex lines are hard to come by I fitted hose and clamps. This is the problem, brake pressure was uneven prior to leak so i decided to redo everything. Bleed entire system removed all dark contaminated fluid and the pedal is on the floor. No answer or reason so I thought, HMMMM this **** sucks. came across this sight and noticed posts about Hydraulic Control Unit Bleeding, Well as long as I had those lines off this is my problem. I can't find the
t90p-50-ala tool or t93t-50-jump and I'm sure that I can't afford them right now. I need a reverse system that's cost effective to bleed this system. I see the power wire for the abs control pump and the power wire for the valve pressure acctuator. What I don't have is a clue on how to make the pump and the valve ruN and open. P.S. HURRRICANE GOSTOV IS COMING MY WAY HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!
