A.J.C.
- March 21, 2014
- Kennesaw, Ga
- 1998 Explorer Limited V8
I recently bought a 2000 Explorer Limited with the 4.0 SOHC and 5r55e transmission. My research tells me I may have a blown valve body gasket but I want your second opinion before I tear into it.
Here are my symptoms. The transmission shifts great but never shifts into over drive. It shifts 3 main times I can tell (1-3) and then if I keep the throttle steady at 40, it seems like the torque converter locks up and the rpms drop 200-300. If I continue to accelerate 55 and maintain that speed, the rpms stay at around 3000. Reverse works well. I have no engine braking if I select "1" with the gear selector.
Does this sound like a bad valve body gasket? I purchased an upper and lower valve body gaskets with the rear servo gasket. Its three pieces. I
I also purchased a new Ford OEM EPC solenoid.
If I have blown gasket, will these parts fix the issues I have described or do I need additional parts?
I also read that I need a new separator plate as well. Was that included in the three piece gasket kit or is that something entirely separate?
I bought this kit off ebay: http://www.ebay.com/itm/261198646115?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Thanks for any help in advance!
