I re-geared and now have blinking 4wd lights on the dash help please | Ford Explorer Forums
tha704mafia
MOORESVILLE, North Carolina
99 XLT
I regeared my 99 explorer with 5r55e tranny and stock transfer from a stock 3.73 to 4.88 i have a lift and 36's so it puts it back to stock rpm range kinda, but anyways i go driving down the road and my 4hi and 4low lights on my dash start blinking and go off and come back on. I can manually flick the switch and here 4wd engage hi and low and they but the lights on the dash dont not light up whats up with that. Can anyone out there help me with this problem.
...the blinking lights is your 4x4 module showing it did it's self test and something is wrong...i think this is a coincidence that it happened when you re-geared. i take it you re-geared front and rear at the same time???
...are you sure when you tested the 4wd that it did engage in both 4 hi and 4 lo??? usually this is related to the shift motor and here is a link to the fix thread....good luck...:D
doh, lol....
http://www.explorerforum.com/forums/showthread.php?t=123542
The shift motor on a 2nd Gen Explorer is the LAST thing that needs to be checked. The shift motor has nothing to do with the 4wd engagement on a 2nd gen Explorer. Its sole responsibility is for selecting high or low range. It does not lock the transfer case. Plus, unless they did something up around the transfer case while they were re-gearing it, I highly doubt it's the problem.
The first place I'd look is at the axle speed sensor on the rear diff. When they changed out the gears, they may have disconnected the sensor, or they may have whacked something inside the diff and broken or misaligned the sensor to the tone ring on the differential carrier. The other thing to look at is that they reconnected the wheel speed sensors on the front wheels, although I would think that if one of these was disconnected, the ABS light would be flashing as well.
Without scanning the GEM DTC's there's no way to know for sure what specific fault the system is detecting. If it's nothing obvious (like a disconnected sensor or frayed wires) I'd pay the labor charge to have someone connect it to an NGS and scan the GEM trouble codes. It sucks, but there's no other way to know without guessing.
And, before someone suggests it, no simple code scanner will be able to scan those DTCs. The AutoZones/Checkers/Kragen/Murrays/Napa et. al. scanners will only scan the ECU or PCM DTC's, not the GEM codes.
-Joe
...after re-reading the original post, i do agree that the speed sensors should be checked and are more than likely the culprit...i myself would take it back to whomever did the gears unless of course it was yourself...:D
...i am still bewildered as to how it could go into 4wd when it is flashing an error ...:scratch:
Not all of the trouble codes result in completely disabling the system. I can't say specifically which ones do, but I do know that when mine fritzed-out last month, if I flipped it to 4high, it was fine, but if I left it in auto for more than 30 seconds, it started blinking and deactivated the system. :dunno
...thats what i thought...as in, would be his best results with the flashing lites and temporary engagement...i am anxiously waiting his feedback as i am curious as heck...i am thinking he just tried engaging both hi/lo and that was it and it didn't have time to cycle the fault...
well guys sorry its been a long time i forgot about this post but i took my x to uwharrie after all this started and it worked perfectly fine 4lo and hi the lights didnt flash but acouple of times when offroad but on the highway they flash like before but no problems so i have decided to just throw a atlas in there and do away with the electronic crap all together i know i know alot of money and what not but christmas bonus from work was very nice this year and i am buying myself i nice present this year haha but thanks for all your help.
...did someone say atlas...:shifty_ey.....:thumbsup:
Yes sir they did i kinda sucks because i can only get the 3.80 because atlas says the 4.30 or whatever with a automatic in low gear the brakes wont stop the truck haha
...be sure to keep us updated...:D
sure thing it will be i alitte bit
