92-XLT-Exploder
- August 17, 2003
- Stratford, ONTARIO
- 92 XLT
I have a 92 XLT with automatic hubs at the front. For the past few months Whenever I would switch to 4x4 I could hear clunking sounds coming from the front of the car. This morning I had to get out of the driveway, and there was tooo much so I had to switch to 4x4, it started fine, but then there was that very loud clunk and the front wheels stopped working and now there is a just a very lound grinding noise when I try to drive in 4x4, and and a very low grinding noise when I drive in 2x4. I tryed driving in reverse for a while but that didn't clear it up, and now when I drive in 4x4 I can see the front drive shaft turning but the front wheels don't turn and there is just that lound grinding noise. Are my hubs completly dead or is there something I can do to fix them ?
Also last sepetember I did a complete overhaul of the engine, and amongst many other things I replaced the thermostat as the engine was over heating and the heater wasn't working. THat solved the problem. A few ago, my upper rad hose blew up while I was driving, and I didn't notice it immediatly as I was on the driving fast on the hwy, I stopped the car when I saw that the engine temperature was going too high. I replaced the hose, and filled up with coolant, but since then the engine temperature gauge keeps fluctuating between cold and medium, and there is very little heat coming in when I turn the heater on. Could it be that the thermostat is dead again ??
