IAC VALVE question is it bad or not | Ford Explorer Forums
huntman58
Fremont calif.
2013 Dodge Advenger
I have a 93 X and the idle is a bit ruff. Starts easy and runs okay fact only problem is the idle both in gear and out. You can feel it in the seats and steering wheel. Warm or cold dose not change a thing.
Now If one would unplug the electric connector to it should that make a deference in how the truck Idles?
I know what I do disconnect mine there is no change at all. I have cleaned it a few times but I am wondering if it bit the big one and I need to finally replace it now.
Im starting to have the same problem also? I may clean it again to see if that helps? Id hate to buy a IAC and it doesnt help....
