IAC valve trouble | Ford Explorer Forums
IAC valve trouble
srj26
Gerald,MO
1998 and 2000
I've read alot on this problem but apperently not enough. My girlfriend's 2000 exlorer 4X4 4.0 sohc(engine code E) has a loud vibration coming from the airbox. After alot of reading I was able to trace it back to the IAC valve. So We took it back again(this is the third one we've put on it in 3 months).
When you start the truck it makes the sound imediately,unplug the IAC for just a second and things go back to normal. Put it in gear and the vibration starts again. I even replaced the plug thinking it was getting a bad connection but that didn't work either. Couldn't find any vaccuum leaks either.
Could a cracked intake cause this? How or whats the best way to tell if theres a crack in the intake?
Inneed of some ideas and things to check for.
Thanks, Steve
