Idiling Problem? | Ford Explorer Forums
Idiling Problem?
9XLT3Explorer
jacksonville,florida
91 4x4
This has been going on for a few days.
What happens is after i go and stop the truck idles so rough it shakes the truck.But this dosent happen when i first start the truck only after it has gone and stoped.Like going and then stoping for a light or traffic.Feels like it wants to cut off but then catches itself.
I just cleaned the MAF and i belive its called the IAC.Took the battery cable off to reset the comp also.
Any suggestions?
Thanks.
It might be prudent to run a can of Sea Foam through the intake.
Good luck .....
Ok sounds good.Ill try that and see if that helps it out.
Thanks.
