idle air control... again... | Ford Explorer Forums
xploded
Grapevine, TX
93xlt 2wd
This might be the dumbest question of the day.
If you unplug the IAC while the vehicle is idling, should the engine quit? I was tinkering around under the hood today, and decided to try this. Well, the engine did in fact quit. I could have sworn I've read about people driving around with the IAC unplugged...
No the engine should idle at about 500 rpm with the IAC unplugged.
It's a pretty common thing to happen. If your truck dies w/IAC unplugged then you should re-calibrate your throttle body/throttle position sensor until it stays running.
