joelwc
- February 12, 2010
- 2002 Sport Trac
2002 Sport Trac request your opinion on an idle issue.
When Cold starting sometimes requires using the gas pedal before it will start. When warm starts fine, but the idle is low, about 500 rpm. Sometimes when the heater is on, and the heater kicks in the idle stumbles and goes to about 400 or so rpm and corrects to 500 rpm. Any opinions as to the cause, I see posts on vacuum leaks, and IAC valve issues? Anyone had similar issue.
Thanks,
Joel
Thanks,
Joel
