03Mach1
- November 28, 2006
- New Orleans, La
- 03 XLT
Vehicle: 2003 Explorer 2wd 4.0 auto ~ 80k mi.
Drove the X last night and everything was acting normal. Started the X up this morning and it felt rough, I figured maybe it was just because it was like 40deg outside and this was just a typical rough cold start and after it warmed up a bit it would go away.
I let it idle for a few, still acting rough, before I decided to pull off and see if it would warm up and settle down. Pulled out the driveway and got about 1 block away when the CEL came on so I turned around and came back home.
Got it in the driveway and shut it down, then re-started it. Once re-started it still felt rough but no CEL at first. Truck ran for about 2 min before the CEL came back on.
Popped the hood and had someone start the truck and the motor was rocking which accounted for it feeling rough, thinking maybe somehow something went wrong inside the engine(spun bearing or something) I was pretty irritated so I figured I better check the codes first before throwing a fit. So I pulled out the OBD II reader and got PO300, PO301, and PO302 - Random mis-fire, Mis-fire cylinder 1, Mis-fire cylinder 2.
I have been searching for over 2 hours trying to figure out how to check the coil pack. I understand checking the primary ohms and secondary ohms but my Haynes manual has no info on the specs or how to test it. I have found diagrams online but I see all different info on what the readings are supposed to be. If anyone has this info it would be very helpful.
Plugs and wires were both replaced within the last year or so, when replaced nothing was wrong but I think the truck was at like 65k or something so I just replaced the plugs, wires and fuel filter when I was doing an oil change.
I also find it hard to believe that 2 plugs or 2 wires would go bad at the same time which is why I am suspecting the coil. The only thing that has me worried is that it is cyl 1 and 2 rather than 1 and 5 or 2 and 6 which operate off the same coil. So in essence I have 1 of 2 coils working and 1 of 2 not working on two seperate coils if that makes sense.
