koldstart
- January 18, 2006
- WA
- 99 Xpo, 4DR, Manual
But my explorer sounds like it is. I really hope it isn't
Its a 99 Explorer, 4 Door, Manual Transmission, AWD, OHV (Vin X), with 86K
At a low idle, you hear a roar, a knocking type sound coming from somewhere inside the engine. It sounds like a diesel if I had to describe it to someone.
I first noticed it after I did an oil change, I used 5W-30, because thats what it recommends. After I heard the noise, I drained that and used 10W-40 hoping that it would thickin things up and eat away the nosie. Must have been a coincidence that it started right after because the noise was still there. I dont hear it under accelleration, just at and idle. If you pull the IAC wires and let the RPM's really come down, it sounds like a small diesel car.
So I took it in to KC Martin, they told me most likely a timing chain raddle. So I hop on here do the search and come up with bookoo results for the SOHC. seems as tho people forgot about the old OHV, but thats what I need some information on.
I did a quick glance at the hanes manual, they say to do a timing chain service you need to pull the entire engine. --- Me have not enough time for that. (If infact that is whats making the noise)
Could it just be simply a tensioner, does that not require removal of the entire engine? does the whole chain need to be replaced with other parts? what other essential information am I missing before go stuffing my hands down the front of the engine?
I've tryed other forums, particularly ford-trucks.com, geting minimal 1/2 baked awnsers from different people. I hope I came to the right place for some better ideas, suggestions and tips.
Please, if you have information on timing chain replacments/what needs to replaced for the sound to go away please let me know.
Thanks !
Thanks !
