RatFRAUD
- May 8, 2016
- Surrey, BC, Canada
- 1999 Explorer/1950 Fargo
Hello mutual enthusiasts!
I have waited nearly 4 years to actually start my 1950 Fargo frame swap project.
I chose utilizing a 1999 Explorer XLT (we have TWO, the other is a 1999 XLS), this was thought to be our backup parts car for the other XLS.
Anyway, the '99 XLT is a complete drive-able 4x4 with approx. 230,000k. While everything is mechanically sound, it suffered a minor RT sideswipe, so that both RT doors are damaged. Usual wear & tear inside and out.
However, after much thinking, I decided to build a Rat Rod/Street Rod combo. This could potentially morph into a daily driver too at some point.
I have already started dismantling the nose of the explorer yesterday.
see this Dropbox link to photos... https://www.dropbox.com/l/sh/xyJbBzsxG7XexEMBnUpSNq
I have taken some early crude measurements determining the frame rail widths and wheelbases, etc. The Fargo is within 1/2" on frame rail, whereas, the Fargo's tires center to center are about 3" wider believe it or not. This is why I chose the explorer over full Mopar using a roll-over Dakota solution.
Now I come to asking for some knowledge. The explorer engine options were 4.0L pushrod/4.0 SOHC (that's what I have!), or a 5.0L. What transmission options do I have? I assume I have a 4R55 behind my 4.0 SOHC, but can I get or use a 5R55e, or can I swap the SOHC to a 5.0?
By building the rod initially with the '99 XLT stock everything, could I later swap out the 4.0 SOHC for a 5.0?
Dave, the RatFRAUD guy.
your welcome to call or txt me at 778-241-1928
