in need of a driveshaft | Ford Explorer Forums
dezel29
seaman, ohio
98 Eddie Bauer 5.0 AWD
98 eddie bauer 5.0 AWD...have looked everywhere and cant find a driveshaft for the 4x4...i cant get a straight answer on the name of the driveshaft, but from the transfer case to the front pumpkin...thanks for anyones help
Try car-part.com.
Search for front drive shaft for your year, make, and model and it will come up with these options:
1998 Ford Explorer
Front Drive Shaft
8-302 (5.0L), (4 bolt Fr output flange)
6-245 (4.0L), (4WD), CV joint
6-245 (4.0L), (4WD), double cardan
8-302 (5.0L), (6 bolt bearing cup Fr output flange)
It's up to you to determine which you need but this will link you to local junkyards. Good luck fellow Ohioan.
