indicator flashing fast on right turn signal | Ford Explorer Forums
Redland
Ford Explorer
Hi there
My right turn signal flashes really fast while the left one is fine, last year this was an intermittent fault (it would go away after using the turn signal a few times)... All three bulbs flash and the hazzards work fine too...
If anyone has any clues they would be greatly received..
oh and its a 2000 NF Explorer
Cheers
Jez
Sounds like the multi function switch is faulty. Creating too much resistance on right turn setting causing the fast flashing. You can get a new one from www.rockauto.com .
yeah, sussed that
if its a resistance problem, is it worth cleaning the bulbs and connections ?
cheers
Its possible to clean the terminals inside the switch if you take it off the steering column. My flashers used to work intermittently and it fixed them. Its a bit fiddly, but nothing flies apart when you separate the switch.
Clean all the contacts and put some switch grease in.
just a quick post to say that I ordered and fitted a new switch and now my turn signals are perfect, thanks ALL for your help
What a great website this is
Jez
Glad you got it working Jez.
