injectors injectors injectors for cologne engine quest | Ford Explorer Forums
smegun
florida
1994 ford explorer xlt
supposedly these are for the cologne engine im trying to get some feedback on which of these are the most prudent upgrade there is even a ev14 bosch has a flyer that promotes the idea of going to a newer injector I cant get all the data together on weather or not the new platic types work with my 94 sequential ohv
like someone wants to sell me refurbs im not really interested or interested in the older ev1 type when the ev6 and 14 are out ill buy adapters if I have …. the flow rates are similar and impedance not quite positive that all these are the same fitment that is I can get em under the fuel rail and not make a engine light come on indefinitely
there steering me twards the yellow versions 700 710 900 tell me what you think I suppose I must eliminate ones destined for returnless systems but these all look similar specs not too certain about physical dimensions
Ford Cologne 4.0L motor
Darkblue 0280156029 / 1L2E-B5A
Bosch EV6CS Fuel Injector
Jetronic port
4 hole nozzle
Flow rates @ 43.5 psi / 3 bar
20 lb per hour
150.7 G per min. (N-Heptane)
209.6 cc per min
14,50 Ohm resistance
Bosch 62256 / 0280156029
Ford 1L2EB5A / 1L2Z9F593BA
Motorcraft CM-4963
other part numbers
Bostech MP2033
GB Reman 822-11138
SMP FJ438
red 0280156028 / 1L2E-C5A
Bosch EV6CS fuel injector
Jetronic port
4 hole nozzle
24.7 lb per hour
186.6 G per min. (N-Heptane)
259.5 cc per min
14.5 Ohm resistance
Bosch 62255 / 0280156028
Ford 1L2EC5A / 1L2Z9F593CA
Motorcraft CM4966
other part numbers
Airtex 4G1276
Bostech MP2034
GB Reman 82211139
Wells M820
yellow 0280155900 / XL2E-A1C
Standard length
Jetronic port
4 hole nozzle
Conical spray
20 lb per hour
210 cc per min
Bosch 62240
Bosch 0280155900
Ford XL2E-A1C
Motorcraft CM-4903
other part numbers
Bostech MP2030
GB Reman 822-11135
SMP FJ300
BWD 63901
Wells M527
Airtex 4G1254
Autoline 161016
Yellow 0280155700
Bosch EV6CL fuel injector
Jetronic port
4 hole nozzle
18.25 lb per hour
137.4 G per min. (N-Heptane)
191.8 cc per min
14.2 Ohm resistance
Bosch 0 280 155 700
Ford F4SEA1B / F4SZ9F593A
Motorcraft CM4768
other part numbers
Airtex 4G1237
Wells M169
SMP FJ10236
yellow 0280155710 / F6VE-A5A
Jetronic port
4 hole nozzle
20 lb per hour
151 G per min. (N-Heptane)
210 cc per min
14.5 Ohm resistance
Bosch 62215 / 0 280 155 710
Ford F6SEA5A / F6VZ9F593AA
white 0280155962
Bosch EV6 fuel injector
Jetronic port
4 hole nozzle
14.1 lb per hour
106.5 G per min. (N-Heptane)
148.1 cc per min
Bosch 0 280 155 962
Ford F87EH1A / F87E9F593H1A
Motorcraft CM4895
dark grey black 0280155734 / 97JF-BA
Standard length
Jetronic port
4 hole nozzle
Conical spray
24.7 lb per hour
260 cc per min
14.5 Ohm resistance
Bosch 0280155734
Ford 97JF-BA
Motorcraft CM-4832
other part numbers
Bostech MP2083
SMP FJ307
GB Reman 822-11168
Autoline 16172
DENSO 297-2014
black 0280158055 adapters ?
Bosch EV14CS fuel injector
uscar port
4 hole Nozzle
20 lb per hour
209.6 cc per min
12,00 Ohm resistance
Ford Cologne
Bosch 0 280 158 055
Ford 5L2EC1A / 5L2Z9F593CA
Motorcraft CM5147 / 4557875
LandRover LR004860
other part numbers
GB Reman 82211193
SMP FJ818
Autoline 161107
BWD 67419
Airtex 4G2007
running the yellow bosch 20# 710s they fit and it runs marginally better as in all cyls ...still not there yet little roughness at stronger accelerations some lag no cel lights similar to new refurbed set of original red cans ...ive got a new maf sitting in front of me but havnt installed it yet
