navin r
- July 1, 2002
- los angeles, ca
- 2001 sport 4 x 4
I talked with a guy from Trailmaster who was able to cross reference some numbers and come up with a "4-Way" coil-over shock to fit my X. You have to also purchase 2 bar pins for the top and two sleeves for the bottom to make it work. You also have to buy some new bolts, lock washers, etc. for the top. The shocks are pretty inexpensive, it was about $120 or so for the works through Rocky Mountain Suspension. I had already raised the rear of my formerly sagging X about 1 1/4" courtesy of some factory shackles extended 2 1/4" by my local welding shop. I was really looking for some extra load carrying capacity without sagging, and wanted to firm up the handling a bit. How do they work? I'd have to say pretty good. Even though these shocks really aren't designed for my X, it's done what I wanted. The ride is about the same, just a bit firmer, and the handling is also a bit firmer. I took a 3 hour drive on the Angeles Crest Highway today, the X felt a lot more comfortable flying around those curves, pretty good for a truck that can also do so some mild off roading. If anyones interested I can post the part numbers.
