jmiah121311
- June 19, 2012
I have a 2002 V8 4.6 Explorer.
Can anybody please tell me where I can locate the wire for the backup lamp and the power supply side wire for the parking brake switch?
I am installing a Pioneer AVH-P3400BH receiver.
This receiver requires you to connect a lead wire to detect the on/off status of the parking brake. There is one wire connected to plunger on the parking brake. The diagram for installation shows there should be two wires, one ground and the other power supply side. I need to clamp a lead to this wire.
My second issue is I also need to connect a wire to one of the two backup lamps. I need to connect to the one in which the voltage changes when the gear shift is in the reverse position. This is for a rear view camera I hope to connect sometimes in the near future that will display on this near receiver.
I am good on everything else, I know how to remove the factory stereo and all of that, but I am unsure of the two things listed above. Any help would be greatly appreciated!
