installing subs today, got a couple? 's | Ford Explorer Forums
JawzSS
Delaware
04 Mountaineer
Installing my 2 JL w3s with a JL 500/1 amp that I had in my.previous truck. I have never personally installed subs before but have my cousin here.to help that has.
I'm going to ne running the subs with the oem radio so I know I need the wiring kit and some type of adaptor to connect them to the head unit.
Never worked on any audio in the mounty yet so any advice would help..
Also to pull the radio I'm assuming the.dash bezel around it needs to ne removed. Does that just pop off with clips?
Where's the easiest place to run wires through the fire wall?
Thanks
I dont think you actually have to take off the bezel, If you use the installation pins. I removed my bezel and it made things a lot easier, just be careful of the wiring.
Got it done, thanks!
