mfg3502
- September 11, 2002
- Buffalo,NY
- 1996 xlt
I have a 96 ex with a bad speedometer.All other guages are working fine.The speedometer goes as high as 50 mph then stays there.When at a stop it slowly retreats back down to the 20 mph range.Then sometimes it works fine.Took it to the dealer,said I needed a whole new instrument cluster.Cost was 333.00 just for the part not counting labor.My question is,could there be a sensor located some where that needs replacing? Some where around the tranny.Is the dealer just taking the easy way out and replacing the whole part itself? Also have a bad third brake light.Following another thread on that issue.Small things are starting to go wrong but they are adding up to big bucks to fix!!This is a great forum and I'm glad I found it.
